cant get pluginns to work. There isnt an effects directory under atomixmp3 directory. HELP!!!
geposted Mon 08 Jul 02 @ 3:33 am
Doesn't the directory exist or aren't there any effects in directory?
The effects files are .dll files and are invisibles. So, you must active the case in explorer (always visible...) in 'folder Option'.
geposted Mon 08 Jul 02 @ 10:45 am
directory isnt there or its invisible
geposted Tue 09 Jul 02 @ 12:56 am
That's weird, the effects directory is automatically added during the install process. If you are running the demo, uninstall it, and re-download and re-install it. If you are running the full purchased version, Try re-installing it. If that doesn't work, uninstall it first and re-install it. Or, go to the atomix folder, and create a new folder within called effects. Then download effects to that directory.
geposted Tue 09 Jul 02 @ 1:29 am
You can even put the effect dll's wherever you want. They don't have to be in the effects folder. It's easier of course, because when you load a plug in, it automatically loads the effect folder :p
geposted Wed 10 Jul 02 @ 11:54 am
