All mobile DJ's out there please tell me what you use or suggest as good software to create playlists in which you can edit/tag mp3's. I need to have one so people can look over my music. I've tried music match jukebox and it doesn't work when transferring songs through a network. I've tried Collectorz MP3 and do not like it, and it doesn't work well. Please help!!
geposted Wed 10 Jul 02 @ 7:16 am
Your question is a little vague, but if you are talking about managing MP3 files and their IDv tags/tagging info, have a look at MP3 Tag Studio, which you can find at www.magnusbrading.com/mp3ts.
Good luck.
Good luck.
geposted Wed 10 Jul 02 @ 2:45 pm
If you use Winamp Player, you can use this pluggin...
it's amazing!!!!
http://perso.club-internet.fr/boyerjl/
EZ-Playlist
You can rename files from a tag
You can write tags from a filename
etc....
you can to catalog your music, specially if you're a DJ
Is a great pluggin.. and easy to use!!!!
Most important: IT WORK!!!
it's amazing!!!!
EZ-Playlist
etc....
geposted Wed 10 Jul 02 @ 10:27 pm
The best Mp3 organizer that I've ever found is Tag&Rename. It's a great tool that does just about everything you want, from mass file renaming to creating tags from file names, both ID3V1 and ID3V2. Check it out at http://www.softpointer.com/tr.htm. It's worth your while!
geposted Thu 11 Jul 02 @ 10:26 am
