how can i make my mix on cd with a studio witch i make more numbers on my cd!
1
2
3
4
5
6
7
8
9
1
2
3
4
5
6
7
8
9
geposted Wed 10 Jul 02 @ 10:23 am
There is an automatic cut in 'option'. But, I don't know if the option work fully in the trial. By the other hand, if you want to cut manuelly your mix, there is CoolEdit for ex.
geposted Wed 10 Jul 02 @ 11:24 am
Do a search for CDRCue. Not all cd writing software will write split tracks as one. Some will still place up to one frame (1/75 sec) of silence between tracks. With CDRCue, you can keep the wav file in one piece, and write out a Cue sheet to be used by a program like CDRWin.
Grimm
Grimm
geposted Wed 10 Jul 02 @ 11:39 am
Ok for CDRwin. Also Easy CD Creator whick work fine (with the studio)
geposted Wed 10 Jul 02 @ 5:15 pm
