i've already unzipped the skin CDJ1000 and all the files are in there, but i still can't load it at the change skin area. i only see the default skin option and no othe options available. My program is a full version which i bought it from atomixmp3 and it's not a crack one. Can someone give me a hand pls. Thankz
geposted Mon 22 Jul 02 @ 7:34 pm
Did you put all the files into the skins folder ? Are you using a skin thats made for the version you have, ie, if you have 2.0 are you using a 2.1 skin ? And lastly, have you tried other skins, there are even a few versions of the cdj skin, so maybe you just got a corrupted one.
geposted Mon 22 Jul 02 @ 8:31 pm
Yes, you have to unzip the files... and they have to be in the atomix/skins folder. If you unzipped them to anywhere else, you have to finbd them and cut and paste them to the proper folder.
Good Luck man, I hope you get this figured out.
geposted Mon 22 Jul 02 @ 8:41 pm
thankz guyz. the thing is the pixel was too high. it will make my other icon smaller. how nice if they have an option to choose from the pixel right.
geposted Mon 22 Jul 02 @ 9:21 pm
