How, or I mean what program do I write shortcut files with?  Wordpad or notepad?
Thanks
    Thanks
geposted Fri 26 Jul 02 @ 4:51 pm
          Is it the xml file, in Skins folder? With notepad, ok.
    geposted Fri 26 Jul 02 @ 9:38 pm
          No, the shortcuts are not in any XML-file and can't be edited manually (unless you figure out how the excellent blokes who created Atomix has formated their ".scu"-files):
just define them from within Atomix.. why would you need an editor when you can define them in 2-3 clicks from within Atomix???
geposted Tue 06 Aug 02 @ 5:39 pm
