Hi,
Yesterday I bought the Hercules DJ Console and installed it with Virtual DJ. I can't scratch with the Jog Wheels, because the program only gives the sound of a "pitch bend". Is there a way to "connect" the Jog wheels to scratch possibility, just like when you're scratching with your mouse in virtual DJ?
Thanks
Thanks
geposted Fri 12 Dec 03 @ 4:20 pm
No, there is no way to do this. Maybe this feature will be include in futur versions but today that's impossible.
Nevertheless, you can scratch with the stick. It's not bad after some trainning.
Good Mix!
Good Mix!
geposted Fri 12 Dec 03 @ 4:38 pm
You can only scratch when the song is not played .
Try cueing a sound and then scratch it with the console.
geposted Sat 13 Dec 03 @ 1:03 am
Thanks for the replies. Hopefully in the future versions it will be available.
geposted Sat 13 Dec 03 @ 2:53 pm
could somebody plz invent a plug-in to do this ?
it would be better if there was such a thing !!
thx
thx
geposted Wed 04 Aug 04 @ 8:32 pm
You can scratch with the dj console in version 2.01, just download the demo and see for yourself!
geposted Wed 04 Aug 04 @ 8:56 pm
