Hi
I am a beginner so don't laugh. :]
Just purchased a nice Pioneer CDM-300 mixer.
Is there a way that I can use atomix just to load the mp3s, not mix them, I mean to use two sound cards that produce sound from each of the players?
If not do you know any other app?
Thanks
Thanks
geposted Thu 01 Aug 02 @ 2:32 am
nice mixer you got yourself there. if i believe you right.. you just want to load the mp3's, and hit play on atomix correct? if that's the case.. no problem. just go into sound configuration and select the correct configuration (2 soundcards and external mixer) then you'll be good to go
phatty720
dave
phatty720
dave
geposted Thu 01 Aug 02 @ 4:36 am
You´ll need the full version...
geposted Thu 01 Aug 02 @ 4:22 pm
tnx a lot dude
Ill try it now
Ill try it now
geposted Sat 03 Aug 02 @ 2:19 am
