Is it possible to goto a cue and start playing automatically. Is there anything you can change in the skin.xml file to achieve this.
Thanks in advance
    Thanks in advance
geposted Mon 09 Sep 02 @ 4:46 pm
          All you need to do is assign 2 functions to one key.  For example if the key for cue 1 was #1 on the number pad also assign play to this shortcut.  This is done in the options menu under shortcuts....
.:DJ Homeboy:.
    .:DJ Homeboy:.
geposted Tue 10 Sep 02 @ 12:25 am
