Topic: Visual add-on
Has anyone used the visual add-on's? It is not particularly important to me. But since the product has this feature, I would like to try it out. I downloaded whatever is available and tried to load into the software, only a dialog box poped up and I have no idea what I should do with it. Else, nothing happened.
geposted Tue 24 Sep 02 @ 5:31 am
You have to install Winamp or Sonique in its original path (...program files...). Then you´ll see the plug ins. But be sure to use a powerful PC because AtomixMP3 + visual needs a lot of power.
plenty of power ... 256 + ram also p4 or Athlon XP
Thanks. I installed the sonique and the visual came on the list for me to select. Though after selecting it, I just saw a blank box. That's probably because my machine is not fast enough. It is a P3 900MHz with 128 ram. But I also downloaded winamp 3 and installed it in both program file/winamp or program file/winamp3, twice. Though the visual worked fine when I used winamp, on the Atomixmp3 when I select winamp visual, a blank popup came out with nothing for me to select.
Did you copy the vissdk.dll in the AtomixMP3/visuals folder?
