Topic: Atomix EQ and Xfaders .....
IS it just me or do the faders (both EQ and level) make static noises when you move them ?
Try this ... put on any tune and kill the mids and treble ... move the faders back and forth and you will see what i am saying !
Cheers.
geposted Wed 25 Sep 02 @ 12:48 am
i tried it there is no problem with me
xp pro
celeron II 1200 mhz
512 ram
sb 5.1
maybe the ram is your problem
trip: is it perhaps the mouse that is generating the static?
I get that sometimes and then it mysteriously fades away... sometimes it helps a bit to make sure that my PS/2-cord is nowhere near the speaker-cables so I think it might have to do with induced electricity between the two cablems or maybe the plugs aren't grounded correctly...
I might be barking up the wrong tree but I've had this kinda trouble.
