Topic: Fatal Error
Fatal Error:
When I tried to save a playlist which consisted of 4 other playlists,
a fatal error occured. The message is basically:
A fatal error occured!
Error Number: 4408fa:fb130c8b
My system is a Pentium III at 900 MHz, 128MB memory.
geposted Mon 14 Oct 02 @ 5:53 am
Have you the last patch which convert Atomix 2.1 to 2.1.1 ?
I think I bought v.2.1.1. I purchased the software only a few weeks ago. The file I have is atomixmp3_v21 whose 3602kb. How can I tell which version I have?
When you launching Atomix, the splash screen indicate you the Atomix version.
See into panel options, the version is indicate at the bottom, on the right.
best option is to mail the error code to service@atomixmp3.com
I have mailed the original message to the service/support group.
