2.0 was an excellent release. Good job. I especially love the new looping feature. It works very well but it only works for 1,2,4 and 8 beats. This should *be* alot more configurable. Why not just use the regular "L" to start where you want the loop and when you are about to exit the loop you want to hear, Simply hit "L" again. This makes it easier to loops songs that don't sound good with 1,2,4, or 8 beats. Something to serious consider for the next update?
geposted Sat 01 Dec 01 @ 2:38 am
yes i agree, there should be way to tap the bpm in and more precise fine tuning of bpm and loops.
adjustement for effects would be great also, the flanger sounds crap in the bottom of the effect
geposted Sat 01 Dec 01 @ 3:13 pm
More likely, your speakers sound like crap in the bottom of the effect. I get that too at high volumes - it's just the bass peaking out.
Turn down the bass EQ.
geposted Mon 03 Dec 01 @ 5:30 am
