The different chosen cue-points should be indicated on the play-slider, so you can visually see how far you will skip in your song if you skip to another cue-point!
Greetz, keep on going guys!
ikke
ikke
geposted Mon 17 Dec 01 @ 10:09 pm
there should be an option where you can use headphones to set yor cues while you are paying music on the other turntble.
geposted Sun 23 Dec 01 @ 1:54 am
There IS a option to listen to the other deck and set cues. Go buy the registered version :-D
geposted Tue 25 Dec 01 @ 12:37 am
Use 2 soundcards, a splitter or a 3d soundcard, a mixer (if you want, not necessary!), and the full version!
Greetz, ikke
Greetz, ikke
geposted Tue 25 Dec 01 @ 3:46 pm
