Would be nice to have the ability to open more than 2 decks to have more than 2 songs going at once,
I know you can open several instances of Atomix but it's too complicated to have to change windows...
geposted Thu 18 Apr 02 @ 9:56 am
I was thinkin' about this too.
When I have like 3 chans I can really start goin' wild with atomixmp3!!
geposted Fri 19 Apr 02 @ 2:04 pm
Going wild with three decks running.. or rather 2 decks running and 1 deck that's constantly messed around with?
What kinda 'puter will be able to handle that load?
geposted Fri 19 Apr 02 @ 2:21 pm
When using "multinstance" you can get more then 1 ATomix
running ...
running ...
geposted Sun 21 Apr 02 @ 8:00 pm
I don't think it will be that heavy for computer IMHO, and multi instance is not what i mean (i guess the topicstarter agrees with me): it's about having 3 channels to record
Like 3 channels on a row...
geposted Thu 25 Apr 02 @ 2:33 pm
Maybe u can buy a SBLive! or Audigy and then use the
"What U Hear" Record option then u can record anything u hear ...
geposted Fri 26 Apr 02 @ 8:19 am
You don't need a specific soundcard for that... most soundcards have a source called "wave-mixer" or "line out" or something like that to choose when you record.
(Using another program to record your mix might be a good idea as Atomix can only record in .wav-format and other programs can record directly to MP3-format)
geposted Fri 26 Apr 02 @ 9:25 am
