i notice when a record's original pitch is altered (either faster or slower) its original bassline becomes somewhat deteriorated. if a progressive or trance record (ex:132 bpm)with a traditional 4:4 beat is modified down to 130 bpm its original bassline becomes slightly distorted. on every 6th or 7th beat, the bass sounds muted or kind of "bent". the original "thump" is not constant and every other 6th beat sounds like "thuff" .this is not obviously evident during real time play (or mixing) but can be easily detected after recorded play. all of my cd players are very sensitive and i can definitely hear the discrepency. i wonder if anyone else has detected the problem because i haven't seen any other posts on the subject matter. will the future versions of atomixmp3 have better sound processing or configuration to correct this problem? thanx for the time.....
geposted Thu 06 Jun 02 @ 7:51 am
maybe you have the time stretching turned on ...
disable that (it's in the options menu) ...
should sound better ...
greetz
greetz
geposted Thu 06 Jun 02 @ 12:53 pm
