the next atomix should have the option of setting more than 1 folder as your home folder, as i have my music on 2 different drives
geposted Fri 14 Jun 02 @ 12:57 am
Same here.. distributing the load and disk-read activity over 2 or more separate harddrives is better for performance so you should be able to set up several home/favorite folders, like C:MP3 and D:MP3..
When we're on the subject, try to keep your MP3's off of the physical harddrive that your system is located at as that will lower performance.. the optimal setup would be the system-partition and perhaps all your applications on one physical harddrive and your MP3's that are read quite a lot and thereby make diskaccess-time an issue on another physical unit.
geposted Fri 14 Jun 02 @ 8:55 am
