i dont know if you can do this all ready, im new to the program, and i dont dj at all, so i would like a software where u can drag songs to a list, and set it for a certain amount of time, and atomix will mix the songs automatically for that amount of time. (it will also take each song and even out the time so that all the songs will be mixed in)...
geposted Thu 27 Jun 02 @ 4:28 am
Try the playlist/automix feature:
http://www.atomixmp3.com/support/manual/playlist.html
geposted Thu 27 Jun 02 @ 10:46 pm
To create playlist and use Winamp from winamp.com
u can drag files to the playlist, save the playlist
in m3u or pls ! then load it in the palylist section
from atomix (Music) U can even drag then down or up
and with the crossfader plugin Preferences/Output/
Configure u can play or list with a pause u can set your self
like 33ms or 300 ms (Millisecond)
Cheers Dj 909
Cheers Dj 909
geposted Thu 27 Jun 02 @ 11:10 pm
(nt = no text)
geposted Thu 27 Jun 02 @ 11:11 pm
OK
Or you can make the playlist in atomix..... it's the screen that opens when you go to the right(if it's not allready opens up)
geposted Sat 06 Jul 02 @ 11:22 pm
