(nt = no text)
geposted Wed 07 Aug 02 @ 2:16 pm
my mistake
Last time I mixed 3 decks with the mutltiple instance option but it was very hard the keep the beats matched. So I can't figure out why it can't be possible to create an atomix program that doesn't contain 3 decks. What if you create a little screen (where the beats are shown) that you can place underneath the original atomix screen. And then you add to that only the necessary tools like equalisers, maybe loops and effects. In style of the "smart repeat" effect. Not much, looks ugly, but works fine! This way you could see the beats more precisely and make more accurate adjustments to the thirth deck. And you can't say that the computer can't handle it because I don't suggest that you must have a beatmatch button or something like that. Just a modified version of the Multiple Instance option.
I hope you understand what I'm thinking about (sorry for my english), I really (REALLY) want that thirth deck.
Let me know if this is possible
GnoedeL
GnoedeL
geposted Wed 07 Aug 02 @ 2:26 pm
If my memory doesn't fail me.. i had a program once that could mix not1 not 2 not 3 but more decks at once (depending on your pc). I don't remeber it's name, but I did not compare to AtomixMP3. If you're still interested, give me a email and i'll look it up, but Atomix rules! ;)
geposted Fri 16 Aug 02 @ 2:14 am
cool
I would appreciate it!!!!!
geposted Sun 18 Aug 02 @ 9:32 pm
BPM STUDIO PRO... is the most profesional dj software for live mixing... you can use 6 dics at one instance..... also, the loop structure is very profesional as well as you got a large varity of cross fadding options.... large number of eqlizers....
it looks like a real deck..... and it is not at all for newbies.... you need months and months to just get your self able to mix two songs correctly.....
geposted Tue 27 Aug 02 @ 6:01 am
