WHEN I LEAVE THE ATOMIXMP3 WITHOUT DO ANYTHING.
IT FINISH PLAYING THE LAST TRACK THAT I PUT AND
STOPES.
SO IT WOULD BE VERY NICE IF YOU PUT A SPICEAL BOTTUN
FOR ETERNAL AUTOMIX, SO I COULD LEAVE THE ATOMIXMP3
AND HE WILL CONTINUE MIXING AUTOMATIC LIKE IN THE
PC DJ RED ( INCLUDING THE OPTION OF THE TIME TO START
THE AUTOMIX, FOR EXAMPLE: 30 SEC BEFORE THE TRACK IS OVER.)
I HOPE YOU HELP ME.
THANKS.
STOPES.
I HOPE YOU HELP ME.
THANKS.
geposted Sat 10 Aug 02 @ 3:25 pm
Umm.. seriously: READ THE MANUAL
There is a button just like that already.
geposted Tue 13 Aug 02 @ 9:46 am
That's very easy to set up... first thing to do is TURN OFF CAP LOCKS!!
geposted Tue 13 Aug 02 @ 4:32 pm
Sorry about the above... if you like using all caps, that's your perogative. Just go to the settings window and you can choose automix start and end points, as well as the mix length. If you choose a 10 second mix length the next song will start when there is 10 seconds left in the playing song and the crossfader will move automatically durring that 10 seconds. Experiment with the cross fader setting, full, smooth, cut... etc until you find a setting that suits your needs.
good luck
good luck
geposted Tue 13 Aug 02 @ 6:04 pm
