When first I started using atomix in version 1.....
the cue function was my favourate... i mean...
i used to cue a position in the track.... and set in on NUM-1
and when i want to start the song... i will start it looping it manually by hitting Num-1 in a repeating manner... which gives it a nice start for some kind of songs....
but when the version 2 had realised..... it got the new loop options in SHIFT+L but the loop which i used to do before on the cue manually is now not accurate... when i start track using the cue and try to hit the Num-1 as i was doing before..... i will find that there is a 1mili-second lag between the two loops...
and that makes my manuall loop awfull...
I wish if atomix return back the accurate cue in the old version... it was very accurate....
I dont know if some one had used BPM Studio.... but the pepole who used it.. they will get to know what i mean by cueing and looping manually.. coz BPM got very accurate cue structure...
thanks and sorry for my english
DJ NANOO
President of UAE Deejay Team
http://www.uaedj.tk
DJ NANOO
http://www.uaedj.tk
geposted Tue 27 Aug 02 @ 6:13 am
