When I start the atomix I have a message saying that the internal database is corrupted then the soft crashes.
How to solve this problem?
why happenned this?
How to avoid it?
Lineker
why happenned this?
How to avoid it?
Lineker
geposted Fri 26 Jan 01 @ 7:54 pm
Ok try going into the atomixmp3 installed directory and deleting the file "mp3DataBase.txt" and "atomixMP3 Internal Database" then restart the program, Hopefully this should solve your problem. You will now have to rescan your drives for mp3/wav files to rebuild the database.
-= R I S C =-
Team Atomix
-= R I S C =-
Team Atomix
geposted Fri 26 Jan 01 @ 8:56 pm
This happened to Me when my pc locked up at a gig. I have found that after you delete the database file and rescan you Mp3's you can copy the new database file to another stop and use it for a backup if it happens again. Just a good way to backup your database. It also helps if you have the same music on mulitple PC's for sync. Databases!!!
Dj RICH T.
Dj RICH T.
geposted Sat 03 Mar 01 @ 10:18 pm
Program CRASH on is inserted an mp3 file at 48 kHz...
WHY???
Pls. report this BUG at bhgeorge@email.ro
WHY???
geposted Wed 21 Nov 01 @ 4:29 pm
It's a known bug of the current version, and it'll be fixed in the next one.
geposted Wed 21 Nov 01 @ 4:32 pm
