Forum: Old versions
Topic: Bug in recording, I guess
When I record my mix and I wanna listen to it after I recorded it ... winamp gives me this message.
But sometimes can I listen to my mix but that happens not very often.
After I've done with my mix I click properly on the mic like they instructed me and still the same problem.
It sounds maybe strange but I don't use my crossfader and I'm thinking that's maybe the cause of it. -- if I turn the option "Auto cut" down it still has the same problem.
:o/
I really want to record my mix sow plz help me
GnoedeL
geposted Fri 25 Jan 02 @ 8:31 pm
WINAMPS MESSAGE: unable to start playback Missing codec or unsupported format.
GnoedeL
hello!!!
I can't record my mix that y do..and i really want to record my mixes!
bye bye
andreanne
Are you mixing in Harware mode?
No I'm not, if found a solution for it.
I have to disable those 2 options that you have for recording.
