Forum: Old versions
Topic: POPING AUDIO
I have had this problem for a while now. I don't know if it is my computer or what but.... When i play tracks on my automix station i get poping/scratching sounds in the background and sometimes it can be really loud. i have tryed lotsa things out but still it is really annoying. My computer is a AMD 2000xp, 512 ram, Sound blaster 128, 160gb harddrive. Anybody Help Me??
geposted Fri 29 Mar 02 @ 11:58 am
MAKE SURE you have the 2.1 version ... No one else has reported similar problems. By the way: its ATOMIX not AUTOMIX !!!!!!!
well I have the same problem....and I have seen some more similar posts.....
its really annoying...
I have fixed my problem with the poping audio. This might sound kinda daft but here goes. It seems that it is whenever i connect to the internet when my atomixmp3 station is running it seems to cause this problem. I don't use my atomixmp3 whilst i am on the internet anymore and it seems to be fine. I don't know for sure that this was the problem in the first place but it seems that if you play tracks whilst connected it causes this problem. If you play a track even once whilst connected then it will stay untill you reinstall the software. kinda wierd really.
Umm... that sounds daft indeed..
I have a DSL-connection and is thus connected all the time, no problem there.. people can even broadcast on the internet with Atomix so there really doesn't seem to be a problem...
However I am a bit curious as to why Atomix want's to connect to the internet (my software firewall shows me a popup everytime I start Atomix)... has this got something to do with the mysterios Charts-option (Collection of chart-info???)
If an internet connection is available atomix checks to see your copy is legal !!!! Also the charts to but this is selectable in the options screen
STU
