Forum: VirtualDJ Skins
Topic: Rhythm Curve Colours
How would you be able to modify the Rhythm Curve Colours in .XML file from green and red to different colours?
Could you tell me all the different codes for the colours?!
Thanks too much!!!!!!!!!
geposted Tue 04 Dec 01 @ 7:04 am
U can change the *.bpm file instead
This whole time i thought you had modify the rhthym curve colours in the .xml file. It worked modifying it in Paint.
That was too easy.
Thanks...!
ok guys, i'm interested in changing colors too but i'm not to good at this. What is the .bpm file or is it the .bmp file. and if it's the bmp, how can you change the color. If you could help me out here with a little bit more detail.
thank you
1. Keep a copy of the skin.xml you want to modify.
2. Open .xml file of the skin you want to change with notepad.
3. In the second paragraph u will see something like that:
/browser
rhythm
size width="740" height="65"/
pos x="30" y="20"/
color chan1="3" chan2="10" both="7"/
4. Modify color chan1="?" chan2="?" both="?"
5. When u finish save us xml file and not just save, to saved .xml and not .txt
6. Run atomix
