Forum: VirtualDJ Skins
Topic: possible eq fader?
is it possible to skin 3 faders that fade seperately between the 3 eqs?
for example have the bass eq set in the middle for both decks, fade to deck A, you hear only deck A bass, as you fade over to deck B, deck A bass goes out and deck B bass comes in?
There would be a total of 4 faders - bass, mid, high, and the whole channel fader.
I think this would be useful if possible.
It doesn't seem possible...
geposted Fri 21 Dec 01 @ 8:03 am
I think it would probably be possible in a future update, but not in a simple skin.
I know there is a new mixer that does this and I might just buy one.
DJ Omni
http://www.productionsomni.com
