Forum: VirtualDJ Skins
Topic: Anyone interested?
Well, I tought: can't I make a layer so you can create a skin easily? You could put this layer in front of a picture or photograph or something, and draw your buttons and co. at the right (indicated) place. The XML file would be the same for every skin. Like this, you could easily make a skin with your girlfriend as ackground (OK, just try not to be disturbed ;-)). Or is it impossible to create something like this? If it's possible, I'll try to create it a.s.a.p. When it's ready, where do I have to post it? In the Skins section?
Greetz, ikke
geposted Mon 24 Dec 01 @ 9:55 pm
i'd say it's possibe, like a template.
