I can't install the program.
When I'm trying to install the program I get this massage:
"An I/O error occurred while installing a file. This is normally caused by bad installation media or a corrupt installation file."
Please help me solve this problem ASAP.
geposted Wed 26 Dec 01 @ 1:19 pm
          You didn't write into the good topic. Please mail this to service@atomixmp3.com.
Hope it helps, Adrien
geposted Wed 26 Dec 01 @ 5:05 pm
          hy when i downlaod the file he has not extension so i rename it to zip or rar but i can't decompress it why can i do
    geposted Fri 28 Dec 01 @ 1:24 am
          Because it's not a zip or a rar (well, if you downloaded it from CNET). It's an exe installation program. Rename it to atomixmp3.exe or something like that.
Greetz, ikke
    Greetz, ikke
geposted Fri 28 Dec 01 @ 11:48 am
          hhmmm, you shouldn't have to rename it.  You might want to change your settings to show file extensions.  But weather the extensions are visible or not, the .exe should still work.  When you download it, just launch it....
    geposted Fri 28 Dec 01 @ 3:04 pm
