Forum: VirtualDJ Skins
Topic: Skin download problem...
Why has every zip file crc error? I could download only one skin yet (edited classic). I so sad because I bought that superb mixer program and can't download the skins for it. The plug-ins ok are came down w/o probplem.... HEEEEEEEEEEEEEEELPPPPPPPPPP!!!!!!!!!!!!!
I want skiiiiiiiiiiiiiiiiiiiiiiiiiiinssssss!!!!!!!
geposted Wed 06 Feb 02 @ 8:34 pm
I don't get any error. Give me your e-mail adres and I can send the zip to you (or the bmp end xml file, if the zip doesn't works).
Greetz, ikke
ikke: vze2hc9x@verizon.net
I need all!!!!!!!!!! I have no idea why I have problem only with the skins, the rest is ok...
I'm mailing it to your adres now, but it are 2 big files (well, 1.92 Mb together!), and I use hotmail, so I can't promise you it will work... I'll see.
Greetz, ikke
The files are to large. Can I send the zip file to you?
of course!
Do you have ICQ or ftp server? (cuerrently I'm burning a cd giMe a little time plz)
I have ftp server so later you can upload if you know what I'm talking about...
ICQ 36628218
uuups I forgat to login....
I don't have one of both. What's the server ip adres?
I solved the problem :DDDDDDDD (fdisk was a usefull utility)
Now I installed win2k pro and have no problem with download... :)) I hapy
(or IE6 or Win98 or both was the problem...)
thanks Ikke
(nt = no text)
