Forum: VirtualDJ Skins
Topic: Invalid Skin when open atomixmp3
last nite i d/l a skin and i try it on atomixmp3, work fine today i open atomix it say invalid skin and dont let me open help!!!
geposted Wed 13 Feb 02 @ 12:54 am
What skin ?
Reinstal atomix or download a skin and Rename it to default.
I think it works.
Just delete the downloaded skin from the Skins file or rename it, then Atomix will open with the default skin. Try another download.
ok.. everytime i go to download a skin or effect addon, it says "Save As".. and then it wants to save as a html document. can anyone help me out here?
The only time I've seen that error was when I had deleted some skins... one of which had been the last skin I had been using before I shutdown atomix. You need to be sure that the skin that Atomix is trying to launch with is actually in the skin folder, along with the xml file
Atomix is doing this to me NOW....and there are NO other skins downloaded, i just have the default skin that came with it (the yellow & Blue skin...version 2.1..paid for)...and it tells me it's an invalid skin file....but i cant figure out wha to do...cuz i havent downloaded any skins!!/......help...please?
DJFunkyFife
i downloaded a skin a lil bit ago...n its 2 bigg 4 my screen...it takes over my whole screen, how do i delete that skin???????
go to C:/programfiles/atomixmp3 and delete any but the default skin
if you like atomix please buy it :)
wow.. this thread is ancient.. it being revived.. hehe,,
Just delete the skin exe file from the atomix folder (I assume u using atomixmp3) n there u go:)
Btw use VDJ now as atomixmp3 is classic:)Use the trial
http://www.virtualdj.com/download.html
Have fun
haha,, simon,, u beat me by a min:)
