Can somebody create a program to make making skins easy... I mean, dreamweaver and frontpage make html easy... So why don't make a program which makes xml easy... Maybe you could make a template for dreamwaever or something (but i don't know for sure)
geposted Thu 07 Mar 02 @ 1:10 pm
Im agree with you! Yesterday I tried to use Pain Shop 7 to make my own skin but I didnt know how to do it!!
Bye,
Dj Coc "Argentina"
Bye,
Dj Coc "Argentina"
geposted Thu 07 Mar 02 @ 2:33 pm
I think you best start by taking the XML file of the standard skin, and just try to edit the BMP files.
geposted Thu 07 Mar 02 @ 7:02 pm
(nt = no text)
geposted Thu 07 Mar 02 @ 8:36 pm
It is not easy to make a new skin. Fisrt you make the lay out (deks, mixer, browzers) and after you edit the xml. You need at least 48 hours work.
geposted Thu 07 Mar 02 @ 9:37 pm
Well ... the easiest thing to do is to follow the bitmap and xml skin of the other skins, and then work from there !
But you have to look into whether they are copyrighted ??
geposted Thu 07 Mar 02 @ 10:51 pm
I creating my skin in Adobe Photoshop 6.0 ( BMP ) and after creating the XML file ( notepad.exe )
My work on one skin is 24 hours.
geposted Mon 18 Mar 02 @ 2:30 pm
You gotta admit, it'd be pretty cool if there was something like a "skin wizard".
geposted Mon 18 Mar 02 @ 5:18 pm
