Hi,
could anybody tell me if there is an option to show more than one rythm window in the same skin or is it limited to one window.
I ask this because i would like to make a skin with several rythm windows.
I' ve tried it in the XML File to make more rythm windows but then it doesn' work.(Error)
thanks for answers
Janosch
thanks for answers
Janosch
geposted Mon 18 Mar 02 @ 5:34 pm
Good question, but I don't think it's possible.
geposted Mon 18 Mar 02 @ 5:59 pm
Yes i tried this once....
I was going to make a rhythm window for each channel... using tha same color on ch1 and both, and black on ch2.
And vice versa on the other window..
But I quickly found out (halfway through the skin) that they both turn black if you change the active desk.... :)
But If you use an external mixer and setup your shortcuts so that there is no need to change active desk... then it is still worth doing.
I hope you see what I'm saying...
- Jim Nordic
- Jim Nordic
geposted Tue 19 Mar 02 @ 12:31 am
Ah..... I remember more clearly now.. I had this problem too...
(getting an error).
... SOOO long ago...
But I also had the issue descrived above....
sorry.
(getting an error).
sorry.
geposted Tue 19 Mar 02 @ 12:36 am
