Is the size of the new skin always going to be bigger than my screen or is there some way to fix that.
Thank you,
Thank you,
geposted Thu 11 Apr 02 @ 12:47 am
You might try making your own (low-resolution) skins.. or ask someone in the nicest possible way to make a low-res-version of it (800x600 for example).
...or if your hardware can handle it, set your desktop to a higher resolution :)
geposted Thu 11 Apr 02 @ 7:51 am
