After a few mixes the crossfader stops responding.
geposted Sun 21 Dec 03 @ 7:17 am
Try to execute VDJ in compatibility mode for Win98
This should solve your problem.
This bug is none and be sure that the developement team is working on. right click on the virtual dj icon properties combatibility chose win 98 millenium and then will play with no problems or close from the bios the hyper threading comand
geposted Sun 21 Dec 03 @ 10:17 am
This seems to work . Hopefully you will resolve this bug.
Thanks for the resolution.
niki
niki
geposted Sun 21 Dec 03 @ 9:09 pm
