Forum: VirtualDJ Skins
Topic: Rythm curve ?
HomeboyPRO InfinitySupport ManagerMember since 2003
Would it be possible to move the rythm curve so it was vertical instead of horizontal.
.:DJ Homeboy:.
geposted Mon 08 Jul 02 @ 2:46 am
That would be cool but atm it's not possible..
Another option(/attribute) I'd like for the beatgraph would be to have deck 1 and 2 separated by a "mirror"-line instead of overlayed.
That way a horizontal grach would have deck one just as the original beatgraph and deck 2 mirrored so that they both share the same zero-line or perhaps the same max-line (when the peaks touch eachother they tunes are matched)
Having this option on a vertical beatgraph would make some pretty stylistic beatgraphs possible... for example a smoke-pillar look sould be very easy to achieve but maybe I'm just daydreaming? :o)
geposted Mon 08 Jul 02 @ 2:16 pm
bluffHome userMember since 2002
is it possible to make 2 windows with the rhythm curves ?
i have there a good idea...
geposted Mon 08 Jul 02 @ 7:35 pm
that is already possible bluff, it is in some skins already
geposted Wed 10 Jul 02 @ 1:39 pm
Really which skin has 2 rythm windows haven't come across it.
.:DJ Homeboy:.
geposted Wed 10 Jul 02 @ 2:52 pm
It must be, otherwise the option(when skinning) to specify which channel(s) are displayed in a beatgraph would be useless.. haven't seen one around but dividing it into to separate beatgraphs is already possible.. the option to flip/rotate them isn't available yet.
*hmmm*... one big, joined, standard beatgraph and 2 miniature beatgraphs for each deck... good be cool... :o)
geposted Wed 10 Jul 02 @ 4:39 pm
