Forum: VirtualDJ Skins
Topic: Saved cues
Is it possible to goto a cue and start playing automatically. Is there anything you can change in the skin.xml file to achieve this.
Thanks in advance
geposted Mon 09 Sep 02 @ 4:30 pm
Please post only once in the forum your question.
.:DJ Homeboy:.
..and yes it is possible in the full version:
specify a shortcutkey to gotocueX when pressing a key of your choice and also specify a shortcut to Play when pressing that same key.
