Forum: Old versions
Topic: [SOUND SETUP] Setting Up a SOUNDBLASTER LIVE Platinum
I have a SoundBlaster Platinum card which has a Headphone jack on the front of it. If I plug my headphones into the jack it disables the speakers. Do you know of a way that I can use my headphones as a moniter and and still be able to hear out of my speakers?????
geposted Sat 20 Jan 01 @ 7:17 pm
If you figure it out, let me know.. I've been thinking about buying it just for that reason alone, so i don't have to reach behind my PC to plug in the headphones to the 2nd sound card. :)
Hi,
if you plug your headphones in the rear speakers jack, it´s monitoring the green player.
Dear users of atomixmp3,
As you have said, Our softawre use the two outputs on a 3d card. The main output is for the red player (speakers) and the rear output is only for monitoring the green player!
Don't forget you can switch between Desk A and B by press the Tab Key
Unfortunetly, the output of the front panel headphone jack is a combination of both the front *and* rear outputs on a Live card. You can, however, disable the mute "feature" of the front panel jack in "AudioHQ", under "Device Controls". Look for the "Live! Drive" tab.
