Hi guys,
Im using two sound cards, and an external mixer. I've set the two decks to be using the different sound cards, but the output only seems to be coming out of one of my sound cards. When I try and use my external mixer, I either get silence or both tracks. However, if I use the mixer inside atomix, I can mix between the two.
Any ideas???
Any ideas???
geposted Fri 27 Jul 01 @ 5:30 pm
First, do you two sound cards work with winamp : try to play music with the first, than with the second. If not, your two sound cards are not properly installed. If it work, you have to select in the sound configuration : 2 sound cards & external mixer.
For more informations, read the previous messages in this forum which deal with your problem.
Good luck, Adrien.
Good luck, Adrien.
geposted Sat 28 Jul 01 @ 2:40 am
Both my sound cards do actually work with Winamp yup. Thats what Im using at the moment to do my sets, seeing that Atomix doesnt work.
I did select that config in it, but it still doesn't work :(
any other ideas????
DJinDecent@aol.com
any other ideas????
DJinDecent@aol.com
geposted Mon 30 Jul 01 @ 10:59 pm
the crosfader must be in the middle. Hope it will solve your problem.
geposted Mon 30 Jul 01 @ 11:20 pm
