When I start the prog. the resolution changes to something like 640x... instead of not leaving my 1024x768. What can i do to run the soft under 1024? and not fullscreen?
thx
Dj Seth
thx
Dj Seth
geposted Sat 22 Sep 01 @ 4:00 pm
Unfortunately, there is no way to change it. I advise you to change the screen resolution to 800/600 while you´re mixing with AtomixMP3.
geposted Sat 22 Sep 01 @ 5:19 pm
NO mama this user can also use the windowed mode.
Click on the second icon on the top right (as the traditional icons of win)
the second will switch the software in windowed/fullscreen mode so you will be able to use the fullscreen (800*600 only) or the windowed mode (at least 800*600)
geposted Sat 22 Sep 01 @ 6:01 pm
...oops, sorry! I always used it with 800x600 full screen because of some poping up progs. :-))
geposted Sat 22 Sep 01 @ 9:25 pm
