Forum: Old versions
Topic: Home Folder
I have an external HD I "made" from an old external Cd-Rw. Anyways it's not always pluged in. I set the home folder to the drive. If they drive is not pluged in and I start atomix It stalls. You should install some kind of check. If it cannot find the home drive go to defult. Thanks guys great work... Oh and adjust the automix timming. We need that feature BAD... Mix on 10s instead of a random kind of number
Thanks
Derek - wattsin@gosfieldtel.com
P.S - Could not login to post because there is someone wrong with the script.
geposted Fri 12 Oct 01 @ 7:10 pm
