Just thought I'd let you all know that Atomix is up and running here on Windows XP and it's going great!
Anybody that was thinking of upgrading, do it. Windows XP is excellent.
geposted Fri 02 Nov 01 @ 5:33 pm
...except for the network configuration. In w2k it´s was easy compared to XP.
geposted Fri 02 Nov 01 @ 8:46 pm
That's true. I'm running XP and the network is a nightmare. Even people with advanced computer knowledge have got stuck with the silly network configurations in XP...
geposted Sat 03 Nov 01 @ 11:10 am
Personnaly, I have to create a LAN between Xp and 98...
If someone has passed to configure correctly his network; let me know :)
geposted Sat 03 Nov 01 @ 2:25 pm
I configured it completely between two XP systems. If it helps, just call me Yan! :-))
geposted Sat 03 Nov 01 @ 6:29 pm
It doesnt work since I installed win2000 or win xp (tried both)
I start the setup file and nothing happens, but I see the CPU is occupied for a 100%!?
This also happens with acrobatreader4
geposted Wed 07 Nov 01 @ 2:30 pm
sounds like you need to reinstall your OS if things as simple as acrobat is causing problems.
XP is really nice... and as far as I can see, the network config is just as easy as win2k... but then again... i know windows networking better than the back of my hand :D
geposted Fri 09 Nov 01 @ 6:55 am
