Forum: Old versions
Topic: Atomix Internal Database
Does the database contain any information about the specification of the machine on which Atomix is installed. I'm asking this question because I purchased a new machine and installed Atomix on it. I then copied the database from the old machine to the new one. Is this okay or will it lead to problems?
Yoda.
geposted Tue 11 Dec 01 @ 3:02 pm
can't say 100% for sure myself (i dont write atomixmp3) but i've done this a few times and it has seemed to work.
This is ok. The old database from 1.2v works in new version. Keep a copy of your database in a different folder.
You wont have any problem...
