Forum: Old versions
Topic: Two soundcard question
Question: what feature does Atomix 2.0 (full version) offers for 2 soundcards?
- Play the Left player with soundcard A en play the Right player with soundcard B?
or:
- Play both Players with soundcard A en monitor (pre-listen with headphones) them with soundcard B (connected to your headphones)
I ask this, because I can't find the button to switch to an other soundcard on the screenshots. Thanks in advance for helping me out.
Pietje
geposted Thu 13 Dec 01 @ 3:56 pm
All of them.
You can connect the 2 cards in 2 channels of an external mixer and you can have each channel of each player. If you dont have external mixer you can have left player to one card and second player to second card.
Other way is to have all mixing in one card and all cue to the other card.
Do you have the full atomix version or not?
Okay, so I have two soundcards installed. How can I set one of the two decks, or both, to be played on my headphones? I can't figure it out.
or:
Biliris Michalis
how does the 2 sound cards thing work??? How can u pre listen then????
I have 2 soundblasters installed in my pc! One is an audigy and other is an live both from creative! My pc is an AMDK6-300MHZ and i have 256 MGB of RAM !!! Only my audigy soundblaster does the scratch and the other have litlle problems! I have a mixer and my operating system is windows 98 2nd edition becausse its more stable! In order to do a mix i have the atomix crossfader in the midle and only my mixer does the mix from one chanel to other chanel! But my problem is that when i have both players of atomix playing and if i serch with the player of the SB audigy foward and backwords in the music, it listens for only a second a little "kzl" Understand? The process in bacwords doest happend! Please help because i bought your program online and i like it very much but on a live party it´s bad!
a 2 sound card configuration is not available in the demo version.
