Forum: Old versions
Topic: exact cue-points
Is there a possibility to set exact cue-points (frames!)?
I tried it in the waveform-display, but there you can´t get exact cue-points. In BPM-Studio is it possible over the search-buttons. Please tell me, if there is a way to do it in Atomix.
Thanks in advance
Mark
geposted Thu 27 Dec 01 @ 11:56 pm
Well, there's no "easy" way to do this in Atomix. Maybe you should take a look in the "atomix internal database"-file (in the atomix root folder) to edit some parameters there? I don't know, because I never tried it yet. Don't be mad if it doesn't works! And before you try to edit, make a backup copy of that file!
Greetz, and hope it works, ikke
Well, you can play the song or skip to the point you want to cue, then press PAUSE, move the graphs with the mouse by holding the left mouse button for the active desk and the right mouse button for the other, and then, if you have your point exactly, cue it. :-)
(DOH).. you can't do that in atomixmp3. there's no way around it.
i haven't myself needed that, but it might come useful when doing some manual looping. (the frame search)
