I just purchased and downloaded Atomixmp3 a couple days ago. This has to be the best program I have used so far. Just one problem...Why do the mids and highs sound somewhat distorted? They sound great on other players. Is this a problem with the software? Has anyone else experienced this? Any suggestions are appreciated.
Pentium III at 933mhz
Windows XP
384 mb
Guillemot Maxisound Fortissimo
Windows XP
384 mb
geposted Thu 03 Jan 02 @ 10:34 pm
Try to install the latest drivers, the latest DirectX and disable "master tempo" in the sound config.
geposted Thu 03 Jan 02 @ 11:33 pm
(nt = no text)
geposted Fri 04 Jan 02 @ 6:16 am
Thanks for replying. But I couldn't find any option to disable the "master tempo" under the sound configuration options. Am I missing something? Also, I have Windows XP as my OS and this comes with Direct X 8.1, so my drivers should be up to date. Any other suggestions?
Philip
Philip
geposted Fri 04 Jan 02 @ 6:18 am
In Atomix, go to Options, then click on Master Tempo!
Hope it helps, Adrien
geposted Fri 04 Jan 02 @ 12:26 pm
Sorry, options, not sound config! :-)
geposted Fri 04 Jan 02 @ 6:27 pm
I am sorry, I am must be missing something or have a different version. Under the Options menu, I cannot find anything that says "Master Tempo." I see lots of other stuff, but not this.
geposted Fri 04 Jan 02 @ 7:06 pm
Discribe what you see please, it woul help.
Adrien
Adrien
geposted Fri 04 Jan 02 @ 8:27 pm
If it isn't Master Tempo, try finding Time Scretch. Sorry for my orthography.
geposted Fri 04 Jan 02 @ 9:53 pm
Ok, this is what I see:
Time Stretch: Enabled
Pitch Range: -34% to 34%
Crossfader: Full
Security: Ask
Tooltip: Enabled
Muliti instance: Disabled
Auto BPM: Enabled
Auto Beatmatch: Enabled
Auto Gain: Enabled
Auto Pitch-Reset: Enabled
Mix Length: 10s
Sound Configuration...
Change Skin...
Select Visual...
Shortcuts...
History...
Crossfader: Full
Security: Ask
Tooltip: Enabled
Auto BPM: Enabled
Auto Gain: Enabled
Mix Length: 10s
Change Skin...
Select Visual...
Shortcuts...
History...
geposted Sat 05 Jan 02 @ 1:33 am
ok so Master Tempo = Time strench. Try without.
Adrien
Adrien
geposted Sat 05 Jan 02 @ 1:56 am
or try the 8% instead of 34% pitch adjust. I use the time stretch, and have never noticed any problems with the sound. But if I need to adjust more than 8% I either pick another song, or don't mix it. It'd be cool of we had a step or 2 in between 8% and 34%... like 16% would be nice. I don't think I'd go for a mix that needed the whole 16%, but it'd be nice to have a smaller option than 34%. Just a thought.
geposted Sat 05 Jan 02 @ 7:45 am
