Forum: Old versions
Topic: Screen Resolution
Guys, I'm using a 19' monitor with a resolution of 1024x768. When I open Atomix I get the skin off to the left, i.e. it seems like the entire screen was shifted to the left.
I've tried to change the skin xml file (tried to change the "X Pos" of the skin but without success.
Can anyone know how can I resolve this problem ?
geposted Tue 08 Jan 02 @ 1:41 am
I think is your os...I use a 21" monitor and I had this problem...Try to move the image by controls display...
And I use 1280 x 1024...
The problem is that when I use the control display to move the Atomix image all the screen is moving so when I close Atomix, the rest of the windows are offset.
To solve this Atomix needs an option for not running on 600 x 800
My flatscreen only gives a clear image on 1024 x 768 so I 've also got problems with the resolution
It should just run on the same resolution as windows, and not change it.
it sounds like atomixmp3 is using some oddball refresh rate that wasn't fine tuned by your display control panel in windows.
