Forum: Old versions
Topic: Sound blaster Live Platinum 5.1 question
Hi guys!
Firstly I must give a big congratulations to the makers of this app :D
Ok, asslickin out of the way:
Will this soundcard surffice in enabling me to play one channel on my speakers & the channel on my comp for recording?
Sorry if this has been answered before but I looked through the back posts & could find a simple enough answer for none technical brain.
Thanx in advance peeps
geposted Wed 16 Jan 02 @ 12:22 am
You can be in softmode, using the front for the speakers and the rear for the headphones. Then you can record with the recording function in AtomixMP3.
Or you can be in hardmode, using an external mixer and plug the mixers record out to the line-in of your SB. Then you must use another recording software, taking the sound from the line-in.
Hope this helps. :-)
Thanx bro! I installed the card today & everything worked perfect :o)
