I cannot seem to be able to choose the 3D soundcard option, even though my card can handle alot of these 3D stuff:
Sensaura based 3D positional Audio with support for Microsoft DirectSound 3D,
EAX 1.0, 2.0
A3D 1.0, I3DL2, MacroFX,
any ideas?
EAX 1.0, 2.0
any ideas?
geposted Sat 02 Feb 02 @ 12:07 pm
When you choose the 3d card option, you also have to choose the speaker and headphone option, or the mixer option. Once you shoose this, hook your speakers up to the front output on the soundcard, and hook whatever you want up to the rear output on your sound card (for most people it's a mixer or headphones). To use the rear output, select the A or B at the top for which one to listen to. If this does not work, then you have a program flaw, and I suggest reinstalling atomixmp3 after saving your settings if you have any that you need to keep.
Hope I could Be Of Assitance :)
-MixMasterMatt
-MixMasterMatt
geposted Sat 02 Feb 02 @ 3:05 pm
What sound card do you have?
If you don't have dual output mode turned on you might not be able to select 3D mode.
geposted Sun 03 Feb 02 @ 12:17 am
