Forum: Old versions
Topic: invalid skin file
all of a sudden i started to get this message...invalid skin file.
help
geposted Fri 08 Feb 02 @ 4:58 pm
Which skin are you using?
If you have this problem even with default skin then reinstall atomix or download a skin and rename it to default.
thanks,problem solved!
