Forum: Old versions
Topic: Changing pitch
Is it possible to change the bpm *and* pitch of a song separately? For example I want to match the pitch of two songs (because they are of two different keys) so I can crossfade between the two choruses. Is there anyway to do that? Thanks.
geposted Sat 16 Feb 02 @ 12:06 am
Sorry, I don't think there is anyway to do that.
Brad
A feature like that would be great because it would allow you to not only match the speed of the song you are mixing in ... it would allow you to match the tone of the other song. This is often reffered to as "Harmonic Mixing".
There is a plugin I have used for winamp (I forget what it is called), and it has 3 controls: Tempo, Pitch and Speed (which controls BOTH tempo and pitch).You can check the winamp site for that plugin, but that wouldn't have much value since you can't mix with winamp. (I tried it .... you just can't do it).
Dave.
I think you use the "pacemaker" plugin...
THATS the one ! Thanks
Where can I find that plugin?
