Forum: Old versions
Topic: Help with Search / Dragging Files
I have duplicate entries listed when i push the search tab (and i do not have duplicate songs saved.) Also, once I try and drag a song to the deck it does nothing. It drops it there but even the name doesnt show up nor will anything play. It works fine under the music tab. Just not the search one. Thanks!!
geposted Wed 24 Dec 03 @ 1:51 pm
You need to re-scan your hard drives. The files that you rename, or move will continue to show up in the search pane until you re-scan the drive.
Well I tried that several times as well as moving the files to another location and I still have duplicate entries showing from the same folder and also cannot drag from the search results to the turntable.
try deleting the mp3database.txt in the virtualdj directory and then rescaning. should fix your problem
